Caravan bonding | Page 3 | on ElectriciansForums
Discuss Caravan bonding in the UK Electrical Forum area at ElectriciansForums.net
A
Adrian Sadler
Hiya
Anyone know whats the minimum size for cable is for...
A. Cu to rod
B. Gas/water/chassis bonding
also if metal framework of the door need extratous bonding?
Cheers
The earth in the consumer unit does back to the genny via the hook up cable so if like what sparky says. Then is rodded to earth. Same thing essentially as using 2 rods. What voodoo earthing system does this come under?
I guess the earth pin in he socket on the genny is attacked to the frame of the genny so if thats bonded to the c.u everything is bonded together. But still - the genny aint centre tapped so where does the earth current go if the genny hasnt got a n-e link?
Its the missing link thats throwing this into a mess
What earth current?
The last thing you want is the damn thing to be centre tapped!
Without the N-E link it will be operating as an electrically seperate system.
Reply to Caravan bonding in the UK Electrical Forum area at ElectriciansForums.net
I wouldn't rely on the ghost immobiliser on its own. My hire vans had them fitted, we lost a key and had a guy come out to cut and programme a new...
