Caravan bonding | Page 5 | on ElectriciansForums
Discuss Caravan bonding in the UK Electrical Forum area at ElectriciansForums.net
A
Adrian Sadler
Hiya
Anyone know whats the minimum size for cable is for...
A. Cu to rod
B. Gas/water/chassis bonding
also if metal framework of the door need extratous bonding?
Cheers
543.1.1 which also references 543.3.1
543.1.1 is to long to type out lol
I know all of that, but my point is what is the point?
The van is plugged in to a 13A socket using a lead with a 2.5mm earth. The socket likely has a 1.5mm earth. So what is the point of using anything bigger in the van? (I suspect I'm missing something obvious here)
As far as the generator goes, it won't be physically capable of delivering an appreciable fault current. Put a fault on the output and the engine will stall. Even of it doesn't stall the Zgen will limit the output massively
Reply to Caravan bonding in the UK Electrical Forum area at ElectriciansForums.net
I wouldn't rely on the ghost immobiliser on its own. My hire vans had them fitted, we lost a key and had a guy come out to cut and programme a new...
