CAT 5 and 230V AC | on ElectriciansForums
Discuss CAT 5 and 230V AC in the UK Electrical Forum area at ElectriciansForums.net
Quick question
I am of course aware of the separation criteria in the regs but in reality what is the longest you can run a CAT 5e cable in parallel to a 230V cable before there are problems.
Just inherited a site where a single piece of flixible conduit has bee laid in a floor to supply power and cat5 to a central point in the room over which a desk will sit. This conduit ( only 3 m) is there to accept both a 2,5mm radial circuit to power the computer and the Cat5 for data.
Will a short run of 3m cause any problems?
Is the CAT5 cable screened and if so is the screen earthed? What data protocol is being used ie analogue, RS232, RS485.....?
3 meters is highly unlikely to cause problems, I usually start getting worried when they run over 20 or 30 meters together.
Reply to CAT 5 and 230V AC in the UK Electrical Forum area at ElectriciansForums.net
