Cat 6 help please | Page 2 | on ElectriciansForums
Discuss Cat 6 help please in the UK Electrical Forum area at ElectriciansForums.net
London
Im just trying to get my head around this.
Basically how do cat 6 systems work,
for example a simple intercom system for a flat where you can buzz them in and can speak to them from the intercom phone..
Where would you get a supply for this because its not just like twin and earth where you can put it in a mcb .. also when wiring a intercom how is it actually wired from stage to stage..like does the supply go to a transformer then ...... then...........
thanks guys
As for your door entry question......ref Leesparky`s diagram....The speech unit is basically 2 amps. + & - are the 12v supply. and T,O,R are the communication paths, O = common, T= talk, R= receive this is constantly running to all telephones for 2 way speech. The I terminal from each phone, is the door release button, giving + 12v when release button is pressed.
The only uncommon cable is the call button, depending on which button is press, a -12v is applied to the phone activating the call buzzer......hope this helps a bit, along with Leesparky`s diagram
Thank you so much mate, that really does help me out alot!
different systems use different things but the system taz mentioned is the usual.
its still wired in beldon but we install video intercoms from time to time and there pretty straight forward but in our case there fed from a control panel rather than directly off a transformer etc.
there bassically the same they just use more cores
The cat5 seemed to be the cause acting as an aerial in both cases, luckily both builds were same builder/contractor, so cables where run up an open riser. So I changed to Beldon screen, and all seemed to stop. One property was only 3 floors.
The control panel is fed from a transformer though?
Most have module units with different voltages, usually 12v for main controller, 5v data controller and separate 12v for door striker/mag....so their only real common path is ov path
Reply to Cat 6 help please in the UK Electrical Forum area at ElectriciansForums.net
All you can do is try it and hope it works out. Shouldn’t be a hazardous condition. Good luck
