Catenary wire | on ElectriciansForums
Discuss Catenary wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I,v heard of earthing the tray(s) but cat wire over head for 25mm armour never, but a guy reckons it,s a must but no metion in the book only a referance to table 42a item 35
P
He is a very clever chap I think I will try to find out his thinking on this, he is ex power station type so could be somthing unique to that
Pict
Pict
Yes, I think I would tread a bit carefully here too. Blokes like this could teach you a lot - a bit like our own Engineer54, Tony & Blindnetpaul.
I don't think there is any regulatory requirement for earthing catenary wires, but i know it was done for the few we had at the factories i served my time at!!
Again these were metal poles not wood poles. Don't think i've ever had the occasion to run a catenary supported overhead cable, since either!! lol!!
Years ago I used to earth them for short overheads to garages etc....but in those days it was common practice to strap a bare T/E to the cat. These days it would always be SWA or plastic conduit so there would be no point in earthing the cat wire.
I remember one of the medium sized warehouses lighting, being completely wired in a made for purpose high tensile steel wire catenary system, with proper system take-off boxes, the whole nine yards so-to-speak. No idea if such systems are still available or still used. Can't remember ever having any problems with the system during the time i was there!!
Pretty sure that the catenery system was fully earthed too.
Reply to Catenary wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
While there are some valid points, no-one has mentioned the most important. YOU NEED THE RIGHT PLUGS. "RJ45"* plugs come in different types...
Brilliant. Thanks Brian much appreciate the advice.
