Cause of massive night time usage? | on ElectriciansForums
Discuss Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
Dammo6
Ireland
HI Guys,
Hopefully someone here might be able to offer a plausible answer to my question because my electricity provider certainly can't.
I had a smart meter installed last March. Analysis of the data shows that we are using, on average, virtually the same number of units between 00:00 and 08:00 are we are between 16:00 and 24:00. The 8-hour period in between is roughly half.
The meter appears to be fine. I turn off the supply and checked the reading before and after a 40 minute period. It was exactly the same.
The company suggests that it is a faulty appliance but I've tried to explain that there is no appliance that is only on during the night that wouldn't also be on in the evening. So surely all the other appliances that would be on in the evening should see a significantly greater reading in total? I hope this is clear.
Can anyone offer an explanation? Is there something glaring obvious that I'm missing?
Thanks in advance
Sounds like a thermal storage electric boiler.
how is the house heated?
Thanks for all the replies. I thought I’d answered last night but I wasn’t sign in on the other device 🙄.
We have ofch and two solid fuel stoves heating the house. No storage heaters.
I’ve started checking individual circuits but no joy so far.
Does this sound like a meter issue? Nobody I've spoken to has ever come across a similar situation. I'd get as much satisfaction from the company 'customer service' dept as I would if I asked them to cut my hair over the phone.
any pictures of the installation, or screenshots of the data that seems incorrect?
It's just a matter of working through it logically.
Mainswitch off overnight - ensure meter reading doesn't increase.
Mainswitch on, but all circuits off overnight - ensure meter reading doesn't increase.
Mainswitch on, but all circuits other than one (say the cooker) off overnight - ensure meter reading doesn't increase.
Mainswitch on, but all circuits other than a different one (say the downstairs sockets) off overnight - ensure meter reading doesn't increase.
.... sleep - repeat....
Until you find one circuit which does increase significantly (most will have a small load such as unused chargers etc).
Once you find out which circuit has the load, repeat the same methodology on that circuit.
It's a long drawn out process, but if you post a list of the circuits you have, we could take a (un)educated guess.
Often unlabelled radial circuits, ring finals etc
Reply to Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
