Cause of massive night time usage? | Page 4 | on ElectriciansForums
Discuss Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
Dammo6
Ireland
HI Guys,
Hopefully someone here might be able to offer a plausible answer to my question because my electricity provider certainly can't.
I had a smart meter installed last March. Analysis of the data shows that we are using, on average, virtually the same number of units between 00:00 and 08:00 are we are between 16:00 and 24:00. The 8-hour period in between is roughly half.
The meter appears to be fine. I turn off the supply and checked the reading before and after a 40 minute period. It was exactly the same.
The company suggests that it is a faulty appliance but I've tried to explain that there is no appliance that is only on during the night that wouldn't also be on in the evening. So surely all the other appliances that would be on in the evening should see a significantly greater reading in total? I hope this is clear.
Can anyone offer an explanation? Is there something glaring obvious that I'm missing?
Thanks in advance
Good that you have discovered that although doesn't explain night time usage as it would be pumping 24/7 in that situation.
The pump would be sized for the system but for a domestic 1kw doesn't sound like an overkill.
Glad you sorted it. May be a good idea to have an indicator lamp somewhere that shows when the pump is receiving power.
There's also the point that the environmental agency can get very excited about sewage flowing where it shouldn't, and can hand out some very substantial penalties.
Reply to Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
