Cause of massive night time usage? | Page 2 | on ElectriciansForums
Discuss Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
Dammo6
Ireland
HI Guys,
Hopefully someone here might be able to offer a plausible answer to my question because my electricity provider certainly can't.
I had a smart meter installed last March. Analysis of the data shows that we are using, on average, virtually the same number of units between 00:00 and 08:00 are we are between 16:00 and 24:00. The 8-hour period in between is roughly half.
The meter appears to be fine. I turn off the supply and checked the reading before and after a 40 minute period. It was exactly the same.
The company suggests that it is a faulty appliance but I've tried to explain that there is no appliance that is only on during the night that wouldn't also be on in the evening. So surely all the other appliances that would be on in the evening should see a significantly greater reading in total? I hope this is clear.
Can anyone offer an explanation? Is there something glaring obvious that I'm missing?
Thanks in advance
What sort of a house is this? Detached, terraced, flat in block, etc?
I only ask because the night time use looks to be coming from something that only powers up with substantial usage overnight, and that tends to be off-peak stuff like storage heaters and off-peak immersions. And e.g. if an older terrace, it is not impossible someone has connected them to one of your circuits e.g. via a party wall.
How many units are we actually talking about here?
What appliances are you using during those time periods?
If you're getting up and going to work or whatever before 8am then, depending on your routine, it's entirely possible that you may be using as much electricity between 0:00 and 08:00 as you are between 16:00 and 0:00
Personally my highest usage in a day is usually in the hour or so after I get up. I'll boil the kettle a couple of times, put the washing machine on and maybe the dishwasher before going out to work.
Hi All,
Firstly, thank you for all the replies and apologies for not getting back to you sooner.
[ElectriciansForums.net] Cause of massive night time usage?
Here's a screenshot of usage from last March. I accept that the word 'massive' may be an overstatement. What I really mean is that I'm amazed that it's the same as 1600 to 2400. As you can see from above, it's pretty consistent throughout the night, rather than concentrated between, say, 0700 and 0800 when people are up for school/work.
The house is a dormer on it's own site.
For comparison, here's 0800 to 1600 for the same period.
And 1600 to 2400
I assume the readings are kWhr, so 0.35 would be a 350watt item running through the night. (Or summation)
A couple of outside halogen lamps on through the night would give this, but I am afraid the only way if you can't find anything obvious, is to switch circuits - given hourly readings you could switch various circuits on through one night a couple of hours apart and find out which circuit is the issue.
One very disturbed night of sleep could get to the bottom of this.
Hope you all had a good Christmas and best wishes for the new year.
I said I’d update this as so many of you were good enough to offer advice. It was as all helpful, especially yours Julie.
After a painfully slow process, I’ve narrowed it down to the pump in the septic tank. Hopefully once I’ve had that replaced I’ll be back to normal usage.
Thanks again.
I am not sure if it needs replacing, sounds like fairly normal usage if you have a 24h agitation pump running.
Would have thought that type of pump would have been on a float/high level switch rather than just through the night so must be on a time switch?
Loading might be normal for that type of pump?
Reply to Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
