Ceiling Light stopped working. | on ElectriciansForums
Guest viewing is limited
Discuss Ceiling Light stopped working. in the UK Electrical Forum area at ElectriciansForums.net
Redditch
Hi, just needing a little help, problem with downstairs light not working, worked for years previously, have no live feed to switch or light connections so I'm guessing that we must have a junction box somewhere & radial wiring so a loose connection in the junction box?. Have 2 red wires into the switch and 3 wires into the light rose. Am I right if so is my only option to either take up the bedroom floor difficult as built in furniture or cut a section of plaster board out of the ceiling, but how do I locate the junction box to minimise the work to rectify, heard that wire detectors are not very good. Thanks and appreciate any help.
yes well lights dont usually run in a ring
Do you have any sort of volt tester?? you need to test to make sure that the cable out of the light before the one not working (if you know which one it is) is live. if it is that will tell you that you have a problem between those two lights. it may be that a nail from a gripper rod has nipped the cable perhaps?
Have you had any work done, is it just the one light, have you checked the fuse box?
well, if you have no live feed to the light then can you trace back to the last light on your circuit?? and see if the live out of that rose is live?
answer ring some one up .
No cable out of the light just black, red and earth coming in. Ordered a Toner/probe to trace the dead cable from the light switch, hoping it will work through the plasterboard?
Think this is what I have, nobody come across this before?
[ElectriciansForums.net] Ceiling Light stopped working.
Reply to Ceiling Light stopped working. in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
As with many of the DIY questions we get on here.... We dont mind helping out (at least most of us... lol) but i would advise to know your own...
Recommended Sponsor News
Hi everyone,
