W
Weymark
Hi
Our first floor ceiling lights are all on the same circuit on the breaker board. The have started flickering sometimes when turned on. The flickering will last up to 5 second then the light will turn on and be fine. Sometimes when another light is turned on within the same circuit all of the others will dim momentarily.
This issue does not happen all of the time, but has happened on all of the lights at various times, and when using all of the switches on the circuit.
All of the fixtures and switches have been checked, and are ok. I believe that the next step may be to start lifting flooring to look at wiring.
I would welcome any advice on possible solutions to try, and I want to try and avoid ripping up floors, should we just live with the flickering, or does this sound like a safety issue?
