Ceiling lights help ? | Page 2 | on ElectriciansForums
Discuss Ceiling lights help ? in the UK Electrical Forum area at ElectriciansForums.net
SUNNYD
London
Hi everyone I'm new to this forum, I was looking at a flat the other day which is beautiful, apart from these lights in the kitchen? , and for such a modern flat I don't understand why they were put in in the first place and also why they are not centred and why is there a lonesome pendant light to the right of them in a really ridiculous position? Is this going to be a really expensive job to deal with to either have them moved, or is there a cheaper way i.e.to run the power from the rose to mount a light elsewhere on the Ceiling i.e... a pendant light over a table for example, is it going to be really messy and what will be the state of the ceiling afterwards. I can just about change a light bulb ?..... could this be a DIY job with careful instruction, or will I need a qualified electrician and roughly how much would this cost? Hope that all makes sense. Thanks in advance.
[ElectriciansForums.net] Ceiling lights help ?
not too big a deal. replace florrys with some nice LED fittings, ditch the pendant. half a day's work.
Thank you ????
[automerge]1567897913[/automerge]
Two 4 spotlight bars with gu10 lamps in place of the fluo’s.... point the lights where you need ‘em
It can depend where the cables enter the back of the striplights. Dead centre or more to one end or the other.
Thank you very much, I was considering keeping the rose for a pendant light over the table.
[automerge]1567898141[/automerge]
Thanks ??
[automerge]1567898206[/automerge]
You may find that the ceiling is a dropped MF plasterboard ceiling with a void above.
Ok thanks ??
As Tel. You may be able to run two LED spotlight bars perpendicular to the existing strip lights depending on where the cable comes out along the length of the strip lights.
If you don't mind me asking is this rented or shared ownership because it looks like a H.A spec?
Hi, no it's private, is there a difference normally then?
[automerge]1567944992[/automerge]
  • [ElectriciansForums.net] Ceiling lights help ?
I think that if it is an MF ceiling with a void above it should be very easy to do what you say regarding moving that pendant you might want to consider installing downlights in replacement of those fluorescent fittings.
Reply to Ceiling lights help ? in the UK Electrical Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
