Ceiling rose wires and flush light | on ElectriciansForums
Discuss Ceiling rose wires and flush light in the Lighting Forum area at ElectriciansForums.net
Lichfield
Hi to all, am replacing an old ceiling light with a flush light and just want to check a few things re the wiring.
Looking at L-R, am I correct here – earth (green), neutral (2 black wires), loop (3 red), switched live (single black)?
Secondly, looking at the wiring diagram for the flush light, do I have to link all the 3 red loop wires to go in the 4th block?
MTIA for any advice here.
[ElectriciansForums.net] Ceiling rose wires and flush light
have you got room in the new light to make the connections, and can you get all 3 cables through the cable entry, ensuring that the outer sheath is within the fitting?
Mmm, I don't like the look/quality of that fitting. The problem you have is pulling the three cables into the cable entry by the block connector as you will have to enlarge it and also using this entry will throw it off centre from the existing fitting. The centre hole does not look like a prescribed cable entry and if you used this the conductors will pass below the lamps.
Reply to Ceiling rose wires and flush light in the Lighting Forum area at ElectriciansForums.net
well spotted, brilliant reply, a potential reply post of the month there. I didn't spot it at first, but I am old lol
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
