Ceiling Wiring Confusion (4 wires)
DIYnewbie
Hello forum,
I'm stumped about how to correctly and safely wire up a new light fitting and stupidly didn't take a picture of the existing ceiling rose set up before removing it. I was wondering if someone here could help me out! I've attached a picture of the four wires that are coming out of the ceiling, and I think the top black wire was going into the hole where the brown wire was connected on the ceiling rose pendant, and the bottom black wire was going into the hole where the blue wire was connected on the ceiling rose pendant. The other two must be part of the switching loop? But I just can't figure it out correctly, and have tried a couple of combinations only for the trip switch to go every time. In terms of the connection of the new light, it has just a blue and a brown going into a junction box that has 4 holes available on the other end, 2 that are lined up with the brown and 2 that are lined up with the blue...
Does anyone know how to correctly fix this? :praying:
Thanks in advance!!
it appears to have cutoff cpc's in those cables, so might not be a difficult fix. if it wers within my area, between £40 and £50 would probably cover a call-out , test and fix.
DIYnewbie,
DPG,
