CH tools cable stripper. Cable damage problems? | Page 2 | on ElectriciansForums
Discuss CH tools cable stripper. Cable damage problems? in the Electrical Tools and Products area at ElectriciansForums.net
Sidecuttters ... you use sidecutters?? Ye big soft Scouse tart!!
We in Geordieland use our teeth on cables up to 6mm and our buttock cheeks for anything bigger!
never use my teeth on T/E, i have to keep them in good condition for SWA. and down in the 'pool we use our bum cheeks for bending galv. conduit.
Well these modern tools, what the hell is wrong with knife if you are that way inclined, else pull back on the bloody cpc, it don't hurt.
it does bloody well hurt if the cpc snaps and your knuckles hit the wall at 20ft./sec.
I have the CK but I have stopped using them on the sheath, especially with 3C&E, as for some reason it stretches the grey insulation at the point the sheath is severed.
Saves time and frustration.
I have just had the same flash bang problem (As luck would have it, at a mates house when I was there!) They are now sitting in the bin and I'm back to cutters! Serves me right for getting lazy!
Reply to CH tools cable stripper. Cable damage problems? in the Electrical Tools and Products area at ElectriciansForums.net
I’m sure I’ve seen an LSF round cable used on sites before as well with an insulated earth. Not flex, something a bit more substantial but not FP...
4K
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
