Changing a ceiling rose to 2 wire light fitting | on ElectriciansForums
Discuss Changing a ceiling rose to 2 wire light fitting in the DIY Electrical Advice area at ElectriciansForums.net
MattHal
ba111lx
Hello,
Trying to change an older ceiling rose into a new light fitting, which only has a 2 cable attachment.
I actually forgot to take a picture of it wired in this time, annoying.
I realise it doesn't need earthing, but there is an additional wire, blue with red casing around it.
Not sure what I'm meant to do with that?
Also assume it's ok to fit the 3 live and 3 neutrals into the one space on the new connector.
Images here:
Thanks!
TL;DR
  • [ElectriciansForums.net] Changing a ceiling rose to 2 wire light fitting
Your new fitting is deemed double insulated (the two squares) and this is achieved by containing wires within that tiny box to keep them separate from metal parts, whether those brown and blue wires achieve separation is debatable. Being made in China I would question it's compliance and quality not something I would fit.
All of your wires cannot be contained within that tiny box hence they need a separate "maintenance free" enclosure in the ceiling void with a single two core flex to the light. Do you know where all those wires connected at the old fitting, i presume there is an extract fan?
The blue with the red tape is likely to be the switched live
To fit that new fitting you will need some Wago's to connect the reds together, the blacks together and the earths together, connect the blue/red to the live on the new fitting and take a neutral from the blacks that are connected together to the fitting
The yellow/red and red connected together would suggest a switched live looped through the existing fitting to another light fixture
Thanks for the reply.
No extract fan.
The yellow cables with the red sleeve (in the plastic connector) weren't previously connected to anything.
I think the 3 reds went into loop in, assume the 3 black went into Flex N as there are 3 spaces there.
Then Flex L has space for 2 cables, so maybe the blue with the red sheath went here.
You can't have all those conductors contained within that fitting, it is deemed Class II.
Any professional forum member in or near Somerset help out?
Needs a little more help than we can offer from afar.
Reply to Changing a ceiling rose to 2 wire light fitting in the DIY Electrical Advice area at ElectriciansForums.net
Thanks will give that a try in a little while Cheers Writing to say thank you very much for that advice, its worked! Really appreciate the help
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
It's no good thinking they need to be sure. Simple continuity tests will verify any breaks.
Brilliant thank you so much for your help 😊 x
