Chasing? | Page 2 | on ElectriciansForums
Discuss Chasing? in the Talk Electrician area at ElectriciansForums.net
if dust would cause problems, i stitch drill with a 7mm or 8mm sds, then chip out with scutch. if it's really hard brick, then i use a sds scutch on a 110V makita.. makes mincemeat out of engineering brick. have on a couple of occasions gone right through the wall, so 2 x 47mm boxes back to back. customer gets an extra socket for free.
Lets settle this once and for all. The best method of chasing is clearly .........
Cue saxophone ....
[ElectriciansForums.net] Chasing?
Mark the wall out , show the customer what to do , go down pub then back home , go back next day its done...LOL..
on recent jobs i cut outline for a box with oscillating multicutter with diamond tile blade. like 5mm deep, helps to control damage to the plasterwork around no big pieces come off. if its a crap wall or crumbly lath then even deeper.
its much better than a chase machine when comes to dust and precision.
dig out the rest with bosch mains sds with a short and wide chisel.
https://www.machinemart.co.uk/shop/product/details/heller-262811-spade-chisel-30mm-x-140mm-long
when done stick the box in with a blob of bonding coat mixed with cement. fix with some red plugs and screws an hour later.
Unless it's 14 Newton concrete block I've never had a problem using a box cutter/sinker. Really quick and just add £30/40 on the price of the rewire for a new cutter,Can't beat it IMO.
Reply to Chasing? in the Talk Electrician area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
As a trainee, one of the things I've tried to focus on to deepen my interest in the world of electrics, is the space for creativity. I've...
