Guest viewing is limited
Hello,
Had a call-out today for a lady who was concerned about 'flashing' lights throughout her house. The 'flashing' happens about once every 10 minutes, and the lamp essentially goes off for a split second. The issue happens across both of the lighting circuits. I've checked at the board and within the lighting JBs in the attic for loose connections but everything is nice and tight. The only thing I can think of is that the cheap halogen GLS lamps in use are causing this to happen, although I'm having trouble thinking of a reason why they would do this (if they even are).
Any thoughts appreciated!
it was not close encounters was it?
Edinburgh
Cheap Halogens Occasionally Flickering
lumenmachine,
lumenmachine,
