Check my wiring diagram | Page 2 | on ElectriciansForums
Discuss Check my wiring diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you, I used microsoft paint. Took ages, are there any better programs to use for wiring diagrams
Wow, didn't know microsoft paint was still around. Paint.net would be an upgrade and it's free. Paint.NET - Free Software for Digital Photo Editing - https://www.getpaint.net/
You'll also need to install dotnet framework if you don't already have it. Download Microsoft .NET Framework 4.6.2 (Offline Installer) for Windows 7 SP1, Windows 8.1, Windows Server 2008 R2 SP1, Windows Server 2012 and Windows Server 2012 R2 from Official Microsoft Download Center - https://www.microsoft.com/en-us/download/details.aspx?id=53344 (redistributable offline installer)
Thank you very much :)
Paint got an upgrade in Windows 10, still slow and annoing to use tho!
Grey & orange are the enable pair,,bit puzzled by the ufh switch wire,maybe controlled by an On for ufh.
Great drawing,must have ago myself,off to work now,will check over again later.
Looks smart that well done, im with Lee on feeding the Ls part. Why don't we set you a challenge and broaden your skill set?
System Boiler-
Unvented Cylinder
1x 2port for hot water
1x 2port for Rad 1
1x 2port for Rad 2
1x 2port for Underfloor Heating
1x tank stat (hot water)
1x circ pump
Programmer
3x roomstats(rad1, rad2, underfloor)
This is an S Plan Plus system so should be a bit more challenging for you.
Reply to Check my wiring diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, I have dismantled my DEFENDER POWER POD 3KVA 110V TRANSFORMER & upon re- connecting the wiring, there now appears to be 2 extra wires...
Thanks for your feedback. Its reassuring to know your experience suggests space won't be an issue. I requested 47mm backboxes for switches when...
