Check my wiring diagram | Page 3 | on ElectriciansForums
Discuss Check my wiring diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Shouldn't brown of the ufh go to sl,Pump to live,Lr & Ls connect to grey & orange respectively
The boiler enable connections in the wiring centre will be volt free. In the diagram gigsy has fed one side of the relay so when it closes when calling for heat it will feed the brown of the UFH 2 port valve which will then motor the valve round closing the micro switch between grey and orange and fire the boiler.
Yea & can see that,
Looking at the control box,Lr & Ls should be grey,orange,Pump to live,valve to switch live,which is controlled by ufh stat.
No, the boiler connections labelled Ls and Lr in the ufh controls are just a pair of volt free connections.
I think you're getting confused by the fact they have been labelled the same as the permanent live out (Ls) and switched live (Lr) of the boiler.
Ok,it does say boiler on the terminals,I can see the actuator is controlled by the stat,the valve terminals just not hitting the spot for me,still a very good drawing,though.
At the ufh box,you already have a L N supply,no need to add another,still think Ls Lr,orange/grey,Pump to L, valve to Sl,bit confusing why you would have it marked Pump only.
Well it would ,would be linked up to the other switch cables orange & grey
Now I'm completely lost, if you do that then what will open the valve?
The Lr and Ls labelled 'boiler' in the ufh control is the volt free contact to signal the external controls when heat is required. This can be any external controls
In this particular system design this needs to open the motorised valve which then fires the boiler.
It isn't another live supply. The control has a mains supply L N E and two volt free N/O contacts one pair labelled pump and the other labelled boiler.
This gives you two switched outputs from the control box.
as I said before, this can operate with any external controls or systems, not just a boiler with a 240V switched live. It could work with a more complex system, a low voltage control system etc etc
Reply to Check my wiring diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, I have dismantled my DEFENDER POWER POD 3KVA 110V TRANSFORMER & upon re- connecting the wiring, there now appears to be 2 extra wires...
Thanks for your feedback. Its reassuring to know your experience suggests space won't be an issue. I requested 47mm backboxes for switches when...
