Chemical Cupboard | Page 2 | on ElectriciansForums
Discuss Chemical Cupboard in the UK Electrical Forum area at ElectriciansForums.net
Midwest
Nearly Esteemed
Oxfordshire
Not so much of an electrical question, moreover if anyone has any experience in swimming pools and dosing of chemicals.
Place I work out has a spa. It has a swimming pool and jacuzzi pool. It has chemical dosing pumps, which are closed in separate closed cupboards. It’s been open for about 3 years.
In the acid cupboard (hydrochloric acid), there’s a slight problem acid contamination. Both dosing pumps have packed up, and the associated conduits, cable tray have been ravaged by the acid, I believe. Not sure where the acid vapour or whatever you call it is escaping from, but it seems it’s attacking everything in the cupboard. The cupboard is ventilated. It’s come to a head, where the pumps have packed up & IP Masterseal socket, was leaking acid! I’ve attached pics. The previous socket had be glanded from the top. So I’ve replaced with a new one, and glanded from the bottom. Before anyone says anything, I have tried cable tying the swa to the cable tray, but the acid burns them off.
My question is, with experience of similar installs, would galvanised conduit & cable be suitable for such an environment? Also, again with previous experience have you known for these cupboards to be enclosed. Some present colleagues, suggest there just needs to be a wall between each chemical application, what installation methods have you seen?
[ElectriciansForums.net] Chemical Cupboard[ElectriciansForums.net] Chemical Cupboard
Reply to Chemical Cupboard in the UK Electrical Forum area at ElectriciansForums.net
