No problem with a connector block as long as you have the room available, its probably less likely to fail than a through crimp.
Discuss Choc boxes in the back of sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Got called to a job yesterday to check 8 double sockets in a bedroom that had been installed by a bloke he knows a couple of months ago. As the room is going to be used for work and is going to have a couple of people working in there he wanted to make sure its safe.
To cut a long story short the fella has extended the ring to these 8 sockets however he has used choc boxes in two of the sockets to extend the cable.
Question is, is this aloud ? if not what would be the solution to extend the cable, when the floors are solid wood ! does not look pretty would be best to crimp ?
Any ideas ??
Reply to Choc boxes in the back of sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
