Circuit wiring issue | Page 2 | on ElectriciansForums
Discuss Circuit wiring issue in the UK Electrical Forum area at ElectriciansForums.net
I
idi
Hi all,
I need some help on a little project i am doing. I have attached a diagram of the circuit to give a clearer understanding of what i need.
[ElectriciansForums.net] Circuit wiring issue
The circuit at the bottom is for a Nexus tablet. I have extended the power switch so points A and B on the diagram are the switch. e.g. which i touch them together for a quick second, the screen turns on, just like the power button on a phone. I want the screen to turn off and on based on a 12v feed. So when the feed is first turned on, i want the button to be pressed just once (points A and B joined and then 'released'), and when the feed is turned off, i want the button to be pressed just once again.
I obviously can't connect the 12v feed to the circuit since all i need to do is join points A and B.
Is this a simple thing to do? How would i approach it? is there anything i can buy made ready for this?
it can be done with electronics, using a dual 556 timer chip, but the problem is power will be needed to switch the tablet off again, which means using the 12v constantly or a battery....if your ok with soldering and components. i can sketch you a drawing.
Yeah i'm confident with soldering. It would be great if you could draw me a diagram.
Circuit should work ok.....choose resistors and caps to give required time, so start with 1k resistors (R1 & R2) and 1uF caps (C1 & C2) should give a few seconds. sw+12v is the switch power supply, 9-12v is constant supply battery or psu.
when power turns on relay 1, relay 2 will com on for a few seconds, shorting A & B.......when power is switch off to relay 1, relay 2 will come on again for a few seconds, shorting A & B, circuit shows 2 555 timer ics, a 556 can be used just check pin layout (didnt have 556 in my cad library) post back a tell us all how you got on...
View attachment Dual Time on Delay.pdf
Reply to Circuit wiring issue in the UK Electrical Forum area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
