Class II | Page 2 | on ElectriciansForums
Discuss Class II in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Replacing lights in office , where there is no earth continuity on the existing circuit.
The new lights are Class II & require no earth.
The client refused rewire of the area, the cabling is T&E but no earth connection..is this legally correct.
This analogy may help: even if you are plugging class 2 appliances into a radial sockets circuit the circuit still requires a cpc to protect the cables.
Same for lighting circuits - even if the cpc isn’t connected to each luminaire it needs to be connected to the next length of cable and so on.
Other than when it forms an earthed sheath around the live conductors, how does a CPC protect a cable?
I accept I didn't word it well, but my meaning was it provides a reliable return current path for edge cases when strange things have happened upstream.
The (obscure) old example coming to mind was when a fuse was removed for the lighting circuit (by customer), the lighting circuit cable was cut, and BANG the main fuse blows. It turned out the CU was wired reverse polarity. If that circuit hadn't had a cpc the customer may have found out about the reversed polarity a much nastier way. Granted, that one is not going to happen every day.
So what is the reason for a cpc in final circuit that is supplying a class 2 fitting in a commercial environment.Is this a regulation requirement. I agree it's required in a domestic environment as a class 2 light could be easily changed with a class 1 fitting by the home owner .
it's there so hopefully a nail or screw penetrating the cable will short L-E and thus result in the OCPD tripping out and killing the circuit. ( apart from a L-E short at a classI fitting).
Reply to Class II in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
You would treat it as a TT installation.
