If you can get to the ends of the cable and access into the void then you could possibly, with lots of effort, if the insulation is not packed in, slide some flexible conduit, perhaps 25mm, over the cable and through the insulation, (with a cover over the end to stop insulation being packed into the conduit); then the cables whilst derated somewhat would be suitable for the applications mentioned.
cheaper and more satisfying to get customer out the back yard and smack him with a wet fish.
@telectrix . You are correct it just means that the upstairs rads may need turning up a bit, depending on the house construction.
Ok for noisy kids though. :)
SG2 0EF
Business Name
M.F Electrical
"Clever" client derated the cables!
Thread Tags
HoverSPRX,
FatAlan,
TrueNAS JBOD Storage Server
