Click flow connectors | on ElectriciansForums
Discuss Click flow connectors in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
Nearly Esteemed
Kent
Would any one have one to hand they could measure or know the dimensions? I'm wondering if they will fit through a 50mm hole? Cheers
Just ask google ;)
[ElectriciansForums.net] Click flow connectors
For the right application a good way of connecting pre-flexed commercial LED downlights . We had some school changing rooms with plasterboard MF ceiling so no access for Klick LCM's wired LSF through joists and clipped. In the socket part you would struggle with anything more than 2 x 1.5mm 3 core & E LSF/PVC.
These are for some 50mm led's that are to be installed in recesses in a few bathrooms.
Reply to Click flow connectors in the UK Electrical Forum area at ElectriciansForums.net
Thanks, it says under the picture of the 4 front plates (in the tiniest writing possible) "Excluding the definity grid pro front plates which do...
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
