Click flow connectors | Page 3 | on ElectriciansForums
Discuss Click flow connectors in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
Nearly Esteemed
Kent
Would any one have one to hand they could measure or know the dimensions? I'm wondering if they will fit through a 50mm hole? Cheers
the restraints are in the lid anyway. see pic. the base is empty as shown.
[ElectriciansForums.net] Click flow connectors
i think you'e put the terminal block in the base instead of the lid.
If you screw the bit with the terminal's in down, you won't be able to push the securing pin from the lid/base into the lid/base to make it MF. Not a problem unless you wish to fix it to something.
Reply to Click flow connectors in the UK Electrical Forum area at ElectriciansForums.net
Thanks, it says under the picture of the 4 front plates (in the tiniest writing possible) "Excluding the definity grid pro front plates which do...
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
