E
Electricalserv
Its all right saying the blokes wrong but we need to see the install etc. RWJ any pic?
Get a cheap Kewtec one like mine, rub it on him to create a static charge then condem him!He seemed to think the risk was his voltage tester was "lighting up" when he touched the cables!!!!!
WOW! It's tough up north ....think it's a case of giving a monkey a pen but not teaching him how to write. i'd get his volt sick, remove the battery and tape a dip in nib on the end. then sellotape it to his clipboard, then shove the lot up his ----.
If it's right in the top corner of the shed I can't see that it's going to be troubled too much by the animals.
I'm a bit concerned about this jobsworth going around condemning every installation that lights up his "tester" though. Have you tried explaining to him what a non-contact voltage detector actually does?
Are you sure he works for the environmental health and he doesn't actually work for you?
Sounds like something off 'the real hustle'.
That certainly seems to be what it's doing here.Provide confusion! (most of the time)
