Code for Armour of Swa not being earthed... | Page 2 | on ElectriciansForums
Discuss Code for Armour of Swa not being earthed... in the UK Electrical Forum area at ElectriciansForums.net
Worcestershire
3 core Swa feeding ip rated plastic sockets outdoors.
He 3rd core of the Swa has been used as a cpc but the armour is not connected to earth; but has been made off with metal banjos. Would this warrant a C2 or C3? I'm assuming as the armour isn't extraneous a C3? ?
Thoughts please ...
Not in the new colours in a three core , they are all phases.
The new convention that seems to have been adopted is to over sleeve the black for the earth in single phase.
Thats because we used to use the YELLOW as the earth and blue as the neurtal?black is the new yellow , as far as im conserned it does not matter what colours you use as long as you sleave them correctly , buts thats another thred :)
I was only avin a laff.
Serious point though, even if the armour was connected to earth, I'd still C2 it if the cores weren't over sleeved with the proper colours.
Cheers
CW
CW.
Cheers
CW
CW.
That is a bit harsh.
In such a case it would only be "dangerous" if some unskilled person started working on the circuit without isolating it first! So C3 or just a comment for me.
Thoughts please ...
Presumably these sockets are insulated so continuity in the swa will not be maintained if connected to earth at one end. The job needs done properly by linking the banjos at each socket as well!
agreed, but it is usual practice to use the black ( sleeved gn/y ) as earth to dissociate the black from neutral. bloody stupid new colours. all the same in the dark.
Reply to Code for Armour of Swa not being earthed... in the UK Electrical Forum area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
There is no homework, and I'll never see these photo again.
