Coding of non bs7671 cables | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Coding of non bs7671 cables in the UK Electrical Forum area at ElectriciansForums.net
Ian1981
Mentor
V.Nearly Esteemed
North east
As title suggests, how many people carrying out EICR code the use of non compliant cables or at least cables not included in bs7671 for fixed wiring such as SY, YY cables.
I see more and more of this type of cabling used for the fixed wiring to anything as a supply to a socket outlet, to a supply for refrigerator units.
Appreciate people’s thoughts and opinions on the matter.
Just out of general interest but RS SY cables are ok for 'fixed installations' according to them.
RS Stock No. 522-676
I questioned this with RS.. They say it's an error and thanked me for pointing it out.
So they are unsuitable for fixed wiring?
I think this is what they are going to change it to.
Note
SY control cables are not suitable for fixed wiring applications requiring compliance with the requirements set out in BS7671.
I’m struggling to think of an application SY is actually suitable for!
We use it a lot in telecoms as it is very flexible and has better mechanical protection than double insulated. SWA can be tricky to get into some of the areas and equipment that is used, SY just fits straight in with very little manipulation.
I like working with SY apart from the braid sticking into the end of my fingers... Had it under the finger nails more than once... :mad:
Also very good for connecting to equipment where a bit of free movement is needed or where there's vibrating equipment.
Been asked to look connect a portacabin that is supplied by SWA to an isolator, whereupon SY has been used over a 5m run in the fabric of the cabin to supply a DB. The cable calcs all work out except for the use of the SY. Part of me thinks change it, but part of me thinks that copper is copper at the end of the day! What would you do?
Reply to Coding of non bs7671 cables in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
Recommended Sponsor News
Hi everyone,
Ian1981
Mentor
V.Nearly Esteemed
North east
United Kingdom
