Coding taken to far | Page 2 | on ElectriciansForums
Discuss Coding taken to far in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just seen more ant this is the best so far.
Code 1 fault Urgent attention and i quote.
"Over the next 10 years the trunking and conduit will corrode recommend installing seperate CPCs for all circuits. "
Did he, by any chance,mention if I was coming into a lot of money during that time :)
very keen, like has been said, most should be 4s if coded atall. Might just be a case of not having much work on so trying to beef up the potential for remedial works?? either way it's not good!
Indeed, and a light switch is normally the only place you may not expect it to be.
A 3 phase board however, you kinda expect it...
Aye, light switch is the obvious one. Luckily with a grid you get a nice warning label to put inside it so the look of it isn't ruined!
But there may be accessories within arm's reach of each other where a potential of 400V exists too.
Reply to Coding taken to far in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
