OP
Geordie Spark
"Hello puddy",
Well done for `researching` about your Boiler / Heating & Hot Water requirements and sticking to what You wanted.
There are various Combination Boilers that are advertised by the Manufacturers to be able to suppy `High Hot Water demand` properties - for example the Ravenheat CSI 150 - a `42 KW Combi` - the published Hot Water supply specifications are:
D.H.W. FLOW RATE 30 °C rise 20.1 l/min
D.H.W. FLOW RATE 35 °C rise 17.3 l/min
D.H.W. FLOW RATE 40 °C rise 15.1 l/min
These stated Temperature rises are from a 10°C Cold Mains inlet temperature.
BUT - the Hot Water outlet pipe from the Combi is still only a 15mm Pipe - so it would still NOT be suitable to run Hot Water to TWO Hot Water outlets / Taps / Showers - especially if they were any distance [pipework] from each other.
Regards,
Chris - Heating Engineer - Registered Gas Engineer.
What size is the Gas Supply pipe for that one Chris?
I'm guessing it's probably 28mm
