G
Geordie Spark
And THAT Chris, is why I don't waste too much of my time writing long and detailed replies on here anymore!!!
No worries m8 no offense taken and yes you right they don't say thanks to the help they get sometimes, but that life
I got a bit lost reading the posts on this thread.
I don't know if it's been suggested or not but here goes.
Many combi's have an adjustable temperature setting for both tap water and for radiator water.
Have you tried raising the setting for the tap water temperature?
I'm quite aware that the mains temperature drops during the winter months.
It's just that before I'd suggest reducing water pressure (which is something the water board do where I live anyway), I'd suggest adjusting the temperature control, as that's usually quite simple, and won't affect a dishwasher or washing machine fill rate.
Excuse my ignorance but, I thought that when 'one' turns the temp dial up on the combi boiler it then regulates the water flow rate to get to the temperature requirement.
Surely turning the mains pressure down or the isolators to the shower is not the answer, get back who ever fitted the boiler or a registered installer to have a look.
A combi does not regulation flow rate of water through the boiler it regulates the gas valve to adjust the burner pressure hence giving more or less heat to the flow passing through the heat exchanger. The temp dial controls the temp of the return pipe to the burner after having passed through the secondary heat exchanger. I have not fully read the post but has the OP checked his hot taps to see if they are 'hot' as it could be a case that the mixer is on its way out, as it seems unlikely to be the boiler as he states it's new, older boiler do have a problem with lime scale in the secondary heat exchanger, also has the installer checked that he has the minimum burner pressure as laid out in the MF as this has a massive effect on hot water temp.
I had problems when Warmfront wanted to fit a new oil boiler they wanted to fit a combi I said no house is too big then they wanted to fit a floor mounted boiler I said no replace like with like i.e. wall mounted then they wanted to fit the 12/18 instead of the 18/25. I told Warmfront to look on bosch website they said no have the boiler fitted outside no I said. Got what I wanted in the end. If you have more than one bathroom then a combi wont heat enough hot water.
