W
woodyalan
Foreword: Apologies if this is repetitious, I did a google and came up with nothing.
Story time: I have just had my meter relocated by Scottish Power and it now sits in a spanking new box, terminating at a dipole isolator and earth block (which I assume is standard stuff). Now, since we are renovating the associated property, it would be convenient to draw power from this supply. My question is, is it possible to use a combination socket (inc RCD+MCB) connected directly to SPs isolating switch (and earth), instead of installing a Consumer Unit? Reasons being:
1. I would like it to fit all the gear into the cabinet - (I realise SP might not be too happy about equipment in their cabinet but the installer seemed unperturbed.)
2. I am trying to minimise costs..so £ small CU+socket > £ combo socket ?
If so, suitable combo-socket suggestions (and approx £) would be much appreciated, (if forum rules allow?_ Otherwise, if a different solution is more appropriate, I welcome your suggestions.
P.S. I will get the job certified or carried out by a professional, depending on whether I decide to DIY or not.
Thanks for your time
