Thought about running a 6x6 galv trunking as low as possible to gland into then, fit a KMF on top of the trunk for each meter and tail out in 25mm double insulated and maybe a Henley block for the cpcs.Does this make sense?
To my mind each isolator should be replaced with a switch fuse unit. The SWA’s need terminating properly. How the hell you do it in the space available I don’t know.
