I'm trying to think of a situation on an installation, control gear or equipment where a fuse in the N might be needed or justified. I'm stuggling.
I suppose it could protect the upstream (where "up" is "closer to source of energy") cabling, e.g. if there was a possibility of the N downstream of the fuse being in contact with a line conductor that has not been fused down itself. But this seems very convoluted!
There was a thread about fused neutrals a few months back (can't find it), I can't recall the reason why N used to be fused at the service head in the old days (if there ever was one!).
It originated in the days of DC transmission, people at the time saw it as being the safest option (they were proved wrong).
I can't think of any reason off the top of my head why a neutral would be fused, it's quite common to have the 0V/Neutral in a control panel to have a drop link fitting,. This is only to aid in testing.
Just posted but it didn't appear? unless i clicked the wrong button!
Is the fused N not something to do with the item at T1?
The Guys sent me the quote from the service agent and it was a faulty PCB causing the drain pump to run continuously, nearly £500 for the part alone when i checked some parts websites so let them crack on!
