Commercial PIR | Page 2 | on ElectriciansForums
Discuss Commercial PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes but code 4 does not imply codes 1 and 2 it would be fundamentally impossible not to mention impractical to suggest to a client that it does
You've lost me 'code 4 does not imply codes 1 and 2' what do you mean?
Well code 4 does not comply with etc, does not mean that the installation has to be ripped out and a 17th edition compliant installation erected
GN3 para 621.2
Reply to Commercial PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
What readings were you expecting for the cable prior to testing? What is the make of the protective device? Is there any previous paperwork [test...
