Its getting to be habitual on this forum that some members are now making it their first port of call to ask rather than research or simply think about what they are asking...
As well established members we are always happy to help but all we ask is the THANKS button is used and the LIKE button too when you feel you have received valued info' - what we also ask is you try to help yourself a little too by researching your query upfront then we are here to fill in any gaps you don't understand ...what we aren't is a free teaching service so rather than just list question after question try a little research.
If someone stop you in the street and asked for directions and you kindly spent a few minutes explaining to them then the just turned away and walked off without so much as a thanks you can understand the way some members can take the 'proverbial' by expecting all and giving nothing back. Im generalising here not pointing fingers!
As for you Contactor - i assume you are not familiar about the basic operation of one and a simple search with give a very easy to follow simple explanation so i suggest to test if it works you apply the rated voltage to the coil and see if it pulls in and the load operates...if so it is functional if you have issues with flickering lights that are not related to their control gear then its possible the contactors contact plates are damaged or not meeting properly.
Remember try help yourself first then at least we feel your not just using the site for every bump in the road you hit.
