Compatible mcb for Hager 3871 | on ElectriciansForums
Discuss Compatible mcb for Hager 3871 in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all
Looked high and low for a Hager 50 amp 3871 for this board. Anyone know which newer 60898s would definately be compatible with these. I know photo is bad the existing ones are Type 2 M3's.
  • [ElectriciansForums.net] Compatible mcb for Hager 3871
Any Hager mcb will fit that board however it has a non compatible main switch fitted in the first place plus another mcb which shouldn't be there. Personally I would be recommending it is replaced unless it can be returned to the original specification of the manufacturer.
Thanks Westward so assume also then that any Hager rcd main switch will also be compatible?
Reply to Compatible mcb for Hager 3871 in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
Thank you!
