Guest viewing limit reached
No it issues a failure certificate and wont have a valid MOT which you will get arrested for, a dangerous circuit would be a civil case. 2 completely different things.
Point I'm making is the garage has advised you your car is dangerous to use and issued the paperwork to say so that's all we can do as electricians issue danger notice isolate and if cutomer accepts this all ok if not put it in writing. If you disconnect circuit from cu what's stopping customer putting it back when you have gone. What you goning to do start ripping the circuit out the walls.
Equipment is the owners property no right to lock/cut off. Issue written warning and if possible get customer to sign. If, at worst case, inform DNO and they may respond if a potential threat to their network/equipment.
responsibilty for any installation remains with the property owner if private / residential , or duty holder if its commercial.
you inform them verbally and follow it up in writing , job done.
i'd like to see it contested in court those that think an electrician is responsible for someone elses crappy wiring for no other reason that they are an electrician and have seen it................
You make a good point, but if things were so bad and there was a chance of children in the premises being harmed if say a particular circuit was left available, I think I would side with the kids rather than the dopey parents and make safe.
We're also not legally entitled to disconnect circuits if the property owner refuses permission but the way I look at it is if I disconnect a circuit with the owners permission to test it and it fails due to a dangerous fault then I have no obligation to reconnect it until it's repaired and safe. Not being allowed to disconnect and refusing to reconnect are not the same thing.
Ah here he is ....... the voice of reason.
What took you so long bonny lad ......... a sleeping elephant on the road??
I caused a commotion on a decent homes programme a few years back, a woman had severe OCD and wouldn't allow any of us in here house because of the mess we'd generate so we waited until she went into hospital and her son let us in to do the periodic.
A list a defects as long as your arm was (legitimately) produced one of which was no earth facility, we had 2 days to rewire, install a kitchen and bathroom. You could barely swing a cat in that place when we were all at full speed.
Poor old bugger died during the night of day 2 so we needn't have busted a gut after all
I'm supposed to be going out tonight and I don't anything clean to wear. If you've ever ironed a grass-skirt you'd know why I've been busy ;).
You should have asked Tony to lend you one of his pink tutus
Right or wrong, we are not the Electrical Police, and therefore have no right in law, to deprive a customer the use of his private property. Them's the facts of the matter!!
As the old saying goes you can't educate pork, so all you can do is leave the offending circuit in a de-energised condition (MCB Off or fuse Removed from carrier) and issue a ''Danger Notice''!! If the customer then wishes to switch the MCB on, or replace the fuse in it's carrier, that's solely down to that person's actions, ...it's not your problem!! You as an electrician have complied with your Duty of Care....
A good example is what I came across 3 weeks ago. Landlord called, needs two broken light fittings re-newing + an EICR for a large 3 bed/two story flat above a shop (unoccupied). Got the keys and off I went, found the two shattered fittings, went to the C/U and opened it up straight away. This is a new board (12 months old) with burn marks on the wall above it!?!?
One of the Neutral bars is burning out. L-E and L-N = 141V on the tails. The main incomer is in the disused shop below with no iso switch in the flat and no access to the shop. The 12 way/duel RCD board in the flat is also feeding the shop below, I have no idea about the the state of the shop that has been standing dormant for years (about 7-9 years I think).......
Q. What would you do???
I turned off the C/U iso. Called the landlord and told him that the electrical installation is unsafe and needs a FULL investigation before a fire starts "I have commend it". I took a couple of pics of the board, sent him a few long texts and saved them all on my laptop to cover my back. I'm not the type of man to throw customers the "It needs a rewire" conversation but this place needs it before anyone lives in it, this is not a patch up job/just fix a couple of fittings type of thing. Told him my price, told him to get other quotes, told him (in the text messages as well) NOT TO TURN IT BACK ON. I think in a court of law that would stand...... BTW no phone call yet about the rewire but the door to the flat has been boarded up. He must be taking this seriously???
i don't think what you're legally allowed to do comes into it really (edit; generally and within reason). for example, i'm not legally allowed to grab a random child by the scruff of their neck and yank them backwards, but if that child was about to step out into the path of an oncoming vehicle, i'd do it without hesitation.
Competency to turn off (condemn) circuits?
jones750,
Knobhead,
