Completion certificate | Page 2 | on ElectriciansForums
Discuss Completion certificate in the UK Electrical Forum area at ElectriciansForums.net
scotland
A customer I've been doing work for since I went self employed is in the process of selling their restaurant and they're needing retrospective planning permission for some dividing walls they had built to split up the restaurant/bar. They need an electrical certificate for extra emergency lights and extra sockets installed. What cert would I need to issue? The work was done before I was on the scene.
Slightly confused here, firstly you are saying "Extra lights and sockets" then work was done before on scene, which is it? if the work has been done then I would tell your customer to get a certificate from the electrician who did the initial works, if that isn't possible then as Kate rightly pointed out you carry out a EICR.
Now if you are talking about "Extra works" as in new, then you will need to either supply a MW if you have used existing circuitry, or a EIC if you install new circuitry, HTHs.
It's extra emegency lights that were installed before I was on the scene. Can't really see where the confusion would come from? It turns out the extra sockets they wanted certifying was sockets I did and they already have the certs.
Firstly I hope my post didn't come across as offensive to you, that was not my focus honest, regarding confusion, I feel the OP you wrote was a little confusing hence my wording in my "hopefully helpful reply", Now you have seen the post and have given more information I now understand fully your point. My answer would be to carry out an EICR on the emergency lighting and a 3 hour test on each light. When this has been completed issue the customer with a EICR and a Emergency lighting testing certificate confirming it is all okay (providing it passes of course), I hope that helps a little and apologies for any earlier confusion.
Reply to Completion certificate in the UK Electrical Forum area at ElectriciansForums.net
I’d say yes go for it.
