Compressor wiring question | on ElectriciansForums
Discuss Compressor wiring question in the UK Electrical Forum area at ElectriciansForums.net
Roto1one
Longview WA
I need to run an outlet for my 220volt air compressor in my shop. I do not want to leave it plugged in constantly and would like to run it through a switch. Can I put a switch in one of the 110volt legs to cut the power?
110 & 220 volt were obsolete before the 2nd world war, as long as it is not a disconnect it is allowed only break one leg of a 240V circuit, it is quite common in air conditioning condenser units, that being said I would use a 2 pole switch rated for the motors horsepower.
Reply to Compressor wiring question in the UK Electrical Forum area at ElectriciansForums.net
It will pull 21.4 amps which is an actual load and the breaker is sized based on the calculated load. Which is 30 amps
The core tech was never Google. The core technology was Nest, and it’s sound. They got bought up by Google looking for a way in to the home tech...
