Guest viewing is limited
B
brizospark
In the wholesalers today the manager said he had seen an attachment for a battery drill that will thread 20 / 25mm steel conduit
Has anyone seen these or know where to get hold of one?
I have used the portable threader but when you are on site it's normally never where you want it and by the time you have gone and found it it would have been quicker to do it by hand.
Die stocks!...with a bit of effort behind em..and theres tecknique of course..as above half a turn on then half a turn off to break the cutting.......and a good cutting paste/fat helps....
Take you a long time with half a turn on then half a turn off! lol :drunk:
If these things are on a battery drill, i bet the battery lasts no time at all. You need a hefty ole current/torque draw to thread a steel pipe. The units the contractor here uses are called ''portable, but it still takes two pretty brawny guys to shift them!! lol!!
the one we had on site was a little bit bigger than a 9 inch grinder and quite a bit heavier,worked on 110v
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
Conduit Threader for drill
Australia
brizospark,
Dan,
