O
Octopus
I think the op needs some local competent assistance ....
Ok, a variation on a theme. In my drawing (dare I call it an artistic masterpiece?)the bathroom light will not be on unless it is switched by the dp switch regardless of whether a switch in the kitchen is operating the fan as well. There is no back feed from the fan because of the use of the double pole switchExcept that's not how it's wired.
From the OP, there are two switches that control the fan as the fan serves both the kitchen and the bathroom. The DP switch is there to separate the bathroom light switching from the fan switching so the bathroom light doesn't come on when the fan is turned on from the kitchen.
It isn't that unconventional! It is just a method of wiring using an sfcu to give isolation to all 3 live fan conductors whilst not isolating the bathroom light (so that you can see what you are doing!). Avoids having a triple pole isolator and is a neat way od doing things
Isolating what the fan?But the neutral cannot be isolated?
Very kind of you, thank you. I do not usually do diagrams for work (because I am lazy) so I just use powerpoint for the forum diagrams.@Richard Burns - What software do you use to produce your diagrams? You always seem to be able to knock them up in double quick time and they are usually pretty darn good.
I already have various accessories drawn out from previous diagrams and use connectors for the cables. Probably slower than a dedicated program but just one with which I am familiar .
