Connect 25 AA batteries in parallel and series | Page 4 | on ElectriciansForums
Discuss Connect 25 AA batteries in parallel and series in the DIY Electrical Advice area at ElectriciansForums.net
I would need see a data sheet on the LEDs, the manufactures name and the type number of the LEDs. Then I could you a complete answer. Ultra low voltage were the regulations do not apply is 30 volts dc and 24 volts ac.
Hello,
I understand now by learning the way to connect light emitting diodes in parallel and series. I understand through reading the way to connect resistors in series or parallel as well. This is my last post here because I am finishing this thread as I understand the way circuits, resistors, series and parrllel circuits work.
Please forum moderators close this thread. I thank you moderators for your help.
Thanks for everyones help that helps myself to understand the way to make light emitting diodes work in different circuits. Thanks for all your time, effort to help myself and many others that read here.
I hope you all are well and I want you to have every success in life. Enjoy your good day, happy week with your loving family and friends. All the best for your future.
Hello,
It is neither recommended nor good electronics practice to connect AA batteries in parallel, if one cell goes low resistance it will drain the others (unless you use a diode on the output of each cell which in the case of AA's isn't practical as the forward voltage drop on the diode will be too significant). AA's also vary from cell to cell, nominally 1.5V alkaline but I've had new ones measure nearly 1.7V. NiMh cells measure 1.2V. (Don't even think about lithium, the cost would be huge)
LEDs work at constant device current for optimum output and the resistance in series with the led or leds is calculated to supply the maximum (or near maximum) current at the highest voltage the power source can provide, after taking into account the LED voltage drop. (or you could use an led driver chip).
You would also need to add in the cost of battery holders, unless he's going to try to solder all the cells together (surely not!).
As an example, a 1.2V nimh cell at say 1500mAh, not taking into account any losses, would provide 1.2x1.5=1.8Wh- you'd need 555 cells to provide 1 kWh, at a quid each that would cost £555. (not that there's anything relevant about a kWh other than it costs about 13 pence from your local electricity supplier)
I should have added that only the first kWh would cost that, you could then recharge them but I'll leave someone else to work out how much it would drop to per kWh if you got 500 charge cycles out of the cells!
Reply to Connect 25 AA batteries in parallel and series in the DIY Electrical Advice area at ElectriciansForums.net
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
EMailed to the forum for you @PCBWay
    • Winner
