Leesparkykent
Nearly Esteemed
Does anyone know of anything specific for this? If not I'll just install a relay to cut the sockets in the booth when the fire alarm sounds.
Discuss Connecting a DJ booth up to a fire alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A sudden loss of power can damage amplifiers beyond repair mate. Be very careful as they're not cheap. You need something that will kill the noise but leave the amps powered.
Maybe things have changed since my roadie days but a band who were on the verge of making it had a big showcase gig in Newcastle a few years back. A power cut killed 14 kilowatts worth of amp rack.amplifiers usually do not have a problem with being turned off.
have a look here, lengthy topic on a specialized forum...
fire alarm audio mute relay? - Speakerplans.com Forums - Page 1
just make sure your relay is up for the job, there may be plenty of current up there.
if in doubt consult the sound engineers in the venue or company that supplies the PA.
otherwise kill the feed to the socket powering the mixer leaving rest of the PA system alone.
Cheers Trev, that makes things a little more difficult than I first thought then.
Like Amlu said, your best bet is to talk to the noisy boys.
There was always a procedure to be followed when powering them up. Gain and output volume on 0, stand by power, power on, gain up, output volume up. Any deviation from that could result in (at best) blown fusesThey don't like to be powered-up too quick either.
I used to use Hill Audio DX-3000's and they were a bit fussy how you treated them but they chucked some power out - 3,000 Watts bridged.
I Can understand the concern about shutting amps down, and possibly dmx lighting....but we are always told the same. Shut the power down. Same in pubs with council Noise Limiters, as soon as the db level goes above a limit, power is cut...I know the bands don`t like the db cut offs.
Reply to Connecting a DJ booth up to a fire alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
