easy hood wink them ,rip it out of their mouths and shove a dummy in
kids love strawberry lolly pops!
Discuss Connecting SWA to Twin and Earth cable? in the The Welcome Forum area at ElectriciansForums.net
Presumably because the new section of cable will be inside the house where SWA won't be required (depending on installation method).
I'd certainly have a little think about whether it mattered or not. In many cases it won't, provided that the cpc meets the minimum requirements over the whole length of the circuit. If the T&E runs into the board, it'll be obvious that the circuit has more than one cable type. If someone was to insert a piece of T&E into the middle of a run of SWA, I'd be less likely to approve.Fair enough, but wouldn't you use a cable which allows you to keep the cpc the same size for the whole run?
Has the OP's question been answered or has the chocolate vs savoury battle been won ;o))))))
I mean 2 core SWA.why 2 x 6mm SWA? do you mean 2 cables or a 2 core SWA?
what's the earthing system, and are ther extraneous metal parts in the garage?
The SWA goes to the basement inside the house so the 6mm twin and earth will be all be indoors and clipped back to the house consumer unit.Why do you want to extend SWA with T&E?
I was taught that you should always extend a wiring system with either the same type or another type which has equal or better protection.
Reply to Connecting SWA to Twin and Earth cable? in the The Welcome Forum area at ElectriciansForums.net
