Connecting SWA to Twin and Earth cable? | Page 3 | on ElectriciansForums
Discuss Connecting SWA to Twin and Earth cable? in the The Welcome Forum area at ElectriciansForums.net
That made me smile , I have seen that . My dog used to drool watching my kids eating ice cream; that was after she had devoured her own .
Golden memories.
@Simon Linton How do you plan to provide the earth?
First of all, physically at the box you have chosen.
Secondly, I guess you are using the SWA? will the steel armour meet the requirements? Or are you TT'ing the distant end?
Fair enough, but wouldn't you use a cable which allows you to keep the cpc the same size for the whole run?
I'd certainly have a little think about whether it mattered or not. In many cases it won't, provided that the cpc meets the minimum requirements over the whole length of the circuit. If the T&E runs into the board, it'll be obvious that the circuit has more than one cable type. If someone was to insert a piece of T&E into the middle of a run of SWA, I'd be less likely to approve.
Why do you want to extend SWA with T&E?
I was taught that you should always extend a wiring system with either the same type or another type which has equal or better protection.
The SWA goes to the basement inside the house so the 6mm twin and earth will be all be indoors and clipped back to the house consumer unit.
Reply to Connecting SWA to Twin and Earth cable? in the The Welcome Forum area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
Sounds more positive.
