Connecting tails to SWA | Page 3 | on ElectriciansForums
Discuss Connecting tails to SWA in the UK Electrical Forum area at ElectriciansForums.net
soulman
Durham
Hi, any suggestions for connecting the tails from the metering equipment within the meter cabinet to armoured cable. (Domestic property). I have seen a clamp used before by a new house builder, but I have been unable to source one.
Cheers
Ive recently had to do similar, where i have extended the tails via a SWA to a new consumer in a large extension ive been working on. I was able to run the SWA externally and terminated it either end into a large PVC IP rated adaptable box. Inside the box i mounted din rail and din rail terminals which in turn allowed me to use your standard double insulated tails where i entered the property into the switch fused isolator at one end and the new consumer unit at the other.
Reply to Connecting tails to SWA in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
