Connector strips
If you double up the cpc's how can you guarantee that the clamp screw will cut down equally into each leg of the conductor, if it cuts one more than the other, you still have a weakness and only one is connected to the "install" as it were.
does no one do the tug test, give it a tug and see if it moves. if it budges re-terminate it
Yes this is the first test I do & teach.
However, if you have a doubled up cpc and the screw has cut into only the "leg" of the cpc going "back" to the "install" how does this help if it has been cut half through already?
It's not quite so simple, as if it moves & you tighten it more you may just cut through it and it could break when you put the accessory back into its back box.
Such things are not so cut & dried.
i used connector blocks yesterday.....
for permanent connections in an adaptor box.......
whats the fuss ??
Nothing wrong with connector blocks at all, except for the fact that you were using them yesterday, Saturday, and we are discussing them on a forum today, Sunday and it's about work when we should all have been & still be off for the weekend enjoying ourselves! ;)
Don't see the 'big issue' with connectors in fact if you ensure both cables are clamped with both screws of the connector probably better then many accessory connections. I have seen a fair few burnt/loose etc. but very few of these are in decent installs and most were in rough DIY jobs/ bad professional jobs. Done properly they are fine IMO
Could even do with showing them to the yanks. lol
You couldn't pull the Yanks away from they're twisters for love nor money!! And the size of some of them, you can understand why they need such massive back boxes for just about everything!!
So if I check an R1+R2 reading, I have to use a wago then? Connector strips will be around way after I'm gone.
