Connectors behind lights & tape | on ElectriciansForums
Discuss Connectors behind lights & tape in the Australia area at ElectriciansForums.net
R
revolt3k
Whats your thoughts when you see this behind fitting's guys
[ElectriciansForums.net] Connectors behind lights & tape
to be honest it looks like every light you have ever taken down. Does anybody think the new hellerman push connectors will kill the old connector block or do you reckon they are just a gimmick?
not a problem infact they are supplied with conector and when done up the conectors are in an enclosure
I think if the building fabric is being utilized as part of an enclosure then it is required to be constructed of non -combustable material......looks like in this instance part of it is a timber joist, however, yes it is a very common way of installing decorative light fitments.
Unfortunately the companies that make these lights dont think of how they are installed, they assume that the flex can be taken above the ceiling, wired into a nice junction box and thats that, either that or they have some stupid tiny connector that only takes one cable rather than the normal 3. So how about some constructive suggestions.
A lot of jobs i have been to work on have a 4x4 junction box near the CU under the floor.Main feed in,feeds to each light and all switch lines back to junction box.There you go,one drop at each light:D
Hi
Tough one the installation doesn't meet the BS regs, as connector blocks in no enclosure and single skin PVC without mechanical protection, connector blocks not assessable unless you take the fitting down, no cable strain at connections and there is possibly more. But you will see this in many houses, and might not be as good as that..
Regards
yeah i will agree that nearly all light fittings of this type are fitted with connectors and do not meet some requirements but hey we only fit them and dont build/make them.
What do you recon to the insulation tape tho. I guess its for a reason of some form?
Reply to Connectors behind lights & tape in the Australia area at ElectriciansForums.net
K
What do you think of this flexible gas hob connector? BES.co.uk | Next Day Delivery On 15,000 + Plumbing Supplies Order gas hob connectors and...
kasser
K
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
